07-28-2024 11:03 AM - last edited on 07-28-2024 12:47 PM by shaiksh
07-28-2024 11:19 AM
how to install and configure large fiber optic servers.
You need to alaborate this question, are you looking to connect Fibre to Servers in DC network ?
or you Looking to use Fibre MUX for termination ?
07-28-2024 11:27 AM
07-28-2024 11:30 AM
and understand it exactly
07-28-2024 11:57 AM
07-28-2024 12:34 PM
Look at the switch, its Catalyst 4500 switch.
show modules it will show you what modules install installed on the switch.,
check the matrix :
check SFP Modules and their distance support, depends on MM or Single Mode ( OS2 or OM2 /3/4)
Hope this help you.
07-28-2024 11:03 PM
If you looking some optical training,(never did myself, since its all learned live environment and each document seperatly)
check below may help you :
