Mix SFP-10G-SR and SFP-10G-SR-S
Hubsi-Smith
Beginner
Beginner
I have an question about the SFP-10G transceiver. For example, I have two Cisco switches, one has an SFP-10G-SR and the other one has an SFP-10G-SR-S transceiver. Would this work in a productive environment?
Hubsi-Smith
Beginner
Beginner
I have forgotten, I would use them only for Ethernet
yes it will work.
note - for non-S SFPs, below are the limitations. normally these are not an issue for general environments.
 OTN or WAN-PHY support
 Optics deployed in non-temperature controlled environments, e.g. rugged/ industrial (RGD)
 Optics plugged on platforms that require extended operating temperature range (EXT)
 TAA compliance
Good luck
KB
