Bookmark
Subscribe
607
MX250 10 gbps uplink
dcampitelli
We are upgrading out internet connection to 10 gbps.   Which uplink transceiver will we need for a fiber connection?
6 Replies 6
balaji.bandi
Do you mean SFP?
if the provider offering Multi-Mode fiber 10G-SR 0r 10G-SR-S can works for you, (i prefer 10G-SR)
If the provider offers a single mode - 10G-LRM you need.
BB
It is multi-mode. SFP is for 1 gig. SFP+ is for 10 gig.
Does it have to be a cisco transceiver? or can I use a finisar ?
So provider side they replacing 1G to 10G right?
I have not tried 3rd party, since if you Log a ticket with TAC and TAC see 3rd party SFP in the device, they do not support for the issue.
but I believe it should work as per I know ( never tested as mentioned)
look at the below thread :
https://community.meraki.com/t5/Security-SD-WAN/Cisco-SFPs-with-Meraki-MX-250/m-p/103843
BB
Thank you. I have some Finisar on hand and will give those a try. If they
do not perform well I will order some Meraki transceivers
They work as expected, have tested some in cisco Switches, but you see some logs, we can ignore it.
BB
marce1000
                              - FYI : https://tmgmatrix.cisco.com/?npf=552
 M.
