08-02-2012 11:23 PM
Is it possible to change the wavelength configured in 10-DME module without disabling or deleting the active circuits? If so, how can this be done? thanks
08-08-2012 08:27 AM
No, the trunk port must be OOS to change the wavelength. And if you have the circuits provisioned as OCHCC, you probably have to delete the circuits and trail since these are all logically provisioned to a given wavelength. And you'll probably need to delete and rebuild internal patchcords, which requires that no circuits/trails are provisioned to the port.
If you only have an OCHNC, you should be a little better off, but in this case, you wouldn't have provisioned circuits or internal patchcords anyway.
08-28-2012 12:35 AM
thanks for the clarification william....
