11-12-2010 07:56 PM
Hello, we have 7 15454s in our network today, 5 in ring id 1 and 4 in ring id 2 (2 are in both rings). Both rings are 2-fiber BLSR. Due to some upcoming changes we need to move away from this 2 ring architecture. Is it possible to merge the rings into 1 ring including all nodes, short of deleting all the circuits, the BLSRs, building new BLSRs and rebuilding the circuits?
Josh
11-12-2010 09:20 PM
Hello Josh,
Merging is not possible, but you can delete both BLSR rings configuration (BLSR protected circuits will be converted to unprotected) and then create a new BLSR ring including all needed nodes.
Delete BLSR
http://www.cisco.com/en/US/products/hw/optical/ps2006/products_tech_note09186a00803863f3.shtml
Configure BLSR
/A
11-12-2010 09:26 PM
You can delete the BLSR Configuration on both rings, then ensure that
all circuits are using unique STS's or STM's then recreate the BLSR as a single ring ID with each node having a unique node ID.
