QSFP-100G-SR4-S, fiber cable polarity
costaspal
Hello everyone
I have to purchase a patch-cable to connect two QSFP-100G-SR4-S transceivers, but I'm asked about the polarity of the MPO cable and I cannot find anything in the transceivers' datasheet.
Polarity A or B is the supported one ?
Thanx, in advance
Costas
7 Replies 7
NOT an LC or SC type, connector !
Thanx anyway
balaji.bandi
It straight cable should work as expected, you only Twist TX and RX, when the ports not coming up or when they go via different comms rooms or patch pannels.
MM cable check the details here :
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/datasheet-c78-736282.html
BB
MPO type cables are 'fixed'.   No way to 'twist' RX/TX.
Thanx anyway
yes i know - i have mentioned in Generic for TX and RX
that is the reason i have mentioned reference guide that uses (MPO-12 (12 fibers))
So make sure you have presentation correctly other side when you using.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/high-density-fiber-patch-mpo-ds.html
BB
In this "Cisco High-Density Fiber Patch Panel, Simplex, MPO and Breakout Cables Portfolio Data Sheet" document, although 'polarity' is not mentioned anywhere, I noticed all "MPO – MPO Multi Mode" cables part-numbers (Table 13) are TYPE B.
I assume this is the 'polarity' I'm looking for, to directly connect two switches via QSFP-100G-SR4-S transceivers.
Thanx
As i have mentioned before depends on where you looking to connect, if other side have same presentation you can connect.
Hope both above documents have clear information - when you connect end to end.
If you looking breakout cable then you need to looks for the same presentation.
BB
