10-29-2018 12:54 PM
have a 9500-24q which only supports 40G connections. Need to provide some minimal 10G (SR) connectivity. How can this be done? looking to use standard mm om-3 type cables between the devices.
Searching in vein
thanks
Solved! Go to Solution.
10-29-2018 02:41 PM
I'm also trying to figure this one out. Docs list CVR-QSFP-SFP10G compatibility from codeset 16.8.1. The modules seem to be detected by the 9500 switch fine, but I can't get connectivity on either standard SR modules, AOC, or twinax to the downstream switches which are typically 3560X.
10-29-2018 02:23 PM - edited 10-29-2018 02:28 PM
Yes, there is a break-out cable that converts 40 Gbps to 4 x 10 Gbps.
Go to the TMG page (LINK) and enter the model of the switch. The supported modules are QSFP-4X10G-LR-S and several of the AOC (up to 10 metres).
10-29-2018 02:41 PM
10-29-2018 02:44 PM
