Question POS point to point with no APS
festerfunk
One side
POS1/0/0
SECTION
LOF = 0 LOS = 0 BIP(B1) = 0
LINE
AIS = 0 RDI = 0 FEBE = 0 BIP(B2) = 0
PATH
AIS = 1 RDI = 2 FEBE = 1119 BIP(B3) = 463
PLM = 4 UNEQ = 0 TIM = 0 TIU = 0
LOP = 0 NEWPTR = 0 PSE = 0 NSE = 0
Active Defects: None
Active Alarms: None
Alarm reporting enabled for: SF SLOS SLOF B1-TCA B2-TCA PLOP B3-TCA
Framing: SONET
APS
COAPS = 0 PSBF = 0
State: PSBF_state = False
Rx(K1/K2): 00/00 Tx(K1/K2): 00/00
S1S0 = 00, C2 = 16
Remote aps status (none); Reflected local aps status (none)
Other end
POS1/0/0
SECTION
LINE
PATH
AIS = 1 RDI = 1 FEBE = 419 BIP(B3) = 859
PLM = 3 UNEQ = 0 TIM = 0 TIU = 0
Active Alarms: None
Framing: SONET
APS
COAPS = 0 PSBF = 0
Rx(K1/K2): C0/15 Tx(K1/K2): 00/00
S1S0 = 00, C2 = 16
My question is the Kbytes what does that mean loss of signal on RX ? Rx(K1/K2): C0/15 Tx(K1/K2): 00/00
There is no Auto protection Switching on this circuit it is straight point to point.
mheusinger
Level 10
Level 10
the meaning of the K1/K2 bytes are defined in "Telcordia document GR-253—Synchronous Optical Network (SONET) Transport Systems: Common Generic Criteria".
K1/K2 = 00/00 means no APS (respective no APS requests)
K1/K2 = C0/15 means
K1 = 11000000, which translates to "low priority signal failure on protected channel"
K2 = 00010101, which translates to "working channel 1 in 1+1 redundancy, bidirectional mode"
So this can mean, that the provider equipment on one end has APS configured, whereas your euipment has no APS configured. APS is local between your interface and the provider equipment (multiplexer).
Hope this helps! Please rate all posts.
Regards, Martin
