SFP-10G question
minhnguyen2818
Does it work if I connect the SFP-10G-SR to SFP-10G-LRM using 10G multimode fiber?
I dont think so, they should be the same SFP model on both ends.
SFP-10G-SR=
10GBASE-SR SFP+ transceiver module for MMF, 850-nm wavelength, LC duplex connector
SFP-10G-LRM=
10GBASE-LRM SFP+ transceiver module for MMF and SMF, 1310-nm wavelength, LC duplex connector
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
SFP-10G-SR=
SFP-10G-LRM=
Leo Laohoo
Will not work.  It's either SR to SR or LRM to LRM.
fiberstorejames
These two modules use different fiber cables as the transmission media, it will not work out.
Bill Ferguson
It will definitely work if you use a mode-conditioning patch cord.
See here: http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/product_bulletin_c25-530836.html
It could work if you use all normal MM cabling. It's hit-or-miss.
