SFP module compatibility on Nexus 3048
19782401a
Hi all,
I have some doubt regarding compatibility of SFP module (GLC-SX-MMD) in SFP+ port in Nexus switch 3000 series
The switch Nexus 3048 have SFP+ port, the compatibility matrix reported in data sheet document does not report the compatibility with GLC-SX-MMD module:
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-685363.html
But in the " Cisco Digital Optical Monitoring Compatibility Matrix" document seems this module be compatible:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/DOM_matrix.html
Could you please help me to clear this doubt?
Gian Luca
Marvin Rhoads
The switch data sheets aren't always exhaustive with respect to the list of supported transceivers.
The best source is the transceiver compatibility matrix. That matrix:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc487719590
...indicates the Nexus 3000 series, including the N3K-C3048TP-1GE, is compatible with the GLC-SX-MMD.
Marvin Rhoads
Thanks Marvin!!!
