sg200-26 problem with MGBSX1
berrymaxcisco
Hi everyboby,
in the office we have 4 switches SG200-26 all connected ones between them in fiber.
Only one however it has problems with mini-gbic SFP transceiver, if inserted it doesn't ignite any red light.
Can he depend on a hardware problem only or does some confiiguration exist?
I have already tried to replace it with other GBIC that works on other switch but il doesn't change anything.
(...before adjourning to the last firware the red light worked.... i have tried to reload the old fimware but he is not changed anything.)
ALL SWITCHES Firmware Version 1.1.2.0 -
Thanks for the support.
Massimo Beretta
Ryan Gadwood
Massimo,
I am not familar with those types of switches but is the port in a no shutdown state? Also you might want to try and physically loop the port back on itself to see if it activiates the port. I have seen on other switches both instances where the port was shut down or a loopback on the port started the laser back up. Hope this helps. Thanks.
Ryan
