Software convert from 15454-TDM (MSPP) to 15454 (MSTP)
Yang Xia
I just got a TCC3 with 15454-TDM (9.2.03) loaded.   Can you suggest what's the procedure to to load MSTP image on it?
Ryan Gadwood
Yang Xia,
To do this you'll need to downgrade to 9.1 software. 9.1 handles both MSTP and MSPP so after you have the shelf at 9.1 you will have the option to upgrade it to the MSTP load you want. Hope this helps.
Ryan
Ryan Gadwood
Yang Xia,
Ryan
Yang Xia
Thanks Ryan.  It works.
