When I provision an OPEN-VCAT in CTC and then look at the Optical card associated with the circuit in CTM, the cross-connects don't show up, they are visible in CTC. Is there a way to force CTM to recognize that there are cross-connects provisioned?
Hi,A strange issue has risen as few fibre links connected from core using STM1 and of 2Mbpsare showing following output and there speed is very slow,kindly help me find out the issue and help resolving the issue.Output of one of the links is as given...
Hy,I have a problem with different GBIC :I have ordered 10 : GLC-LH-SM (LX/LH) GBIC for my customer. I have 5 links between 4503 and 2960G with Single Mode Fiber (patch cord in SMF too). Only 3 link are working properly.In wrong link :I have tried to...
I have a user that has a two node 15310CL network that is not optically connected to my ONS network. He needs a PRS level timing source for his network, but there is no external timing source available to him in that building. Can I program the ONS15...
Hi,I have a building on campus, which is connected to my core switch over obsolete MMF (the link is approx 500m, but I can't indentify what type of fibre cable it is). Recently I upgraded core switch from 4006 to the new 4506E. In the 4006 I used GBI...
Hi all,I'm running fine with a 3750X Stack, 3 TE plugged in and multiple GB's.Now I'm following errors in my logs:May 11 13:16:43 MET-1DS: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1/2: Rx power high warning; Operating value: -0.5 dBm, Threshold value: -...
I have a WS-C4948 and want to have it use two of its SFP slots instead of the GigabitEthernet port 47& 48.I have put in two glc-lh-sm in SFP slots 45 & 47 and have them connected to a C3560G-24TS which also have two glc-lh-sm installed.I cannot figu...
We are trying to set up a new out-of-band network and were wondering if this is possible. Thanks Tom!
HiI am having one 3750X switch with GLC-SX-MM SFP uplink to a third party Media converter and inserted one Cisco SFP GLC-SX-MM into third party Media converter which was blank but the uplinke port is down. I want to know whether Cisco SFP is support...
I am looking to bridge a Cisco WS-4948 to a Cisco C3560G-24TS elsewhere in the same building.I have a fibre patch panel that links the two locations which only has connections for single mode fibre.As the connection between these two switches will on...
What is the difference between this both cards MXP_MR_10DME_C and MXP_MR_10DMEX_C?
Hello everyone,can anyone tell me what the distance limitation of single mode fiber is using all Cisco equipment before the signal has to be regenerated? Also, what speed can be expected at the maximum distance? The desire is to aquire some dark fi...
Hi All,What is the Transmission rate for Single Mode Fiber with 8 cores? 8 cores are divided in to 2 pairs of each.Any help is much appreciated.Thanks
Is it possible to upgrade a fixed rate OC12 card that's part of a UPSR to an MRC card that's in a different slot without rebuilding the circuits? I can't think of any other way to accomplish this without rebuilding. Please help.Thanks for your time...
We run a 100 Mbit trunk over 62.5 MM fiber to a remote building. We replaced the building’s single switch.Old:2950C-24 switch with integrated 100BASE-FX optic using a MTRJ to SC fiber patchNew:2960S-24TS-L and GLC-GE-100FX= SFP optic with LC to SC fi...
Subject | Author | Posted |
10-07-2024 12:40 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
