10-23-2020 09:42 AM
Bonjour
en transmission j'ai la situation dessous
Optical Optical Temperature Voltage Current Tx Power Rx Power Port (Celsius) (Volts) (mA) (dBm) (dBm) --------- ----------- ------- -------- -------- -------- Gi0/4 39.5 3.30 20.5 -5.5 -6.7
mais toujours la synchro est internal
aussi l'interface est instable , comment s'il vous plait lancer un diagnostic pour connaitre la cause ?
Oct 22 19:56:09.323: %LINK-3-UPDOWN: Interface GigabitEthernet0/4, changed state to down Oct 22 19:56:09.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan301, changed state to down Oct 22 19:56:09.327: %LDP-5-SP: 172.30.33.10:0: session hold up initiated Oct 22 19:56:09.327: %IFDAMP-5-UPDOWN: interface GigabitEthernet0/4 update IP Routing state to DOWN, interface is not suppressed Oct 22 19:56:09.327: %IFDAMP-5-UPDOWN: interface Vlan301 update IP Routing state to DOWN, interface is not suppressed Oct 22 19:56:09.819: %NETCLK-6-SRC_UPD: Synchronization source GigabitEthernet0/4 status (Signal Failure) is posted to all selection process. Oct 22 19:56:09.819: %NETCLK-6-ENTER_HOLDOVER: System Internal synchronization source is selected. Oct 22 19:56:09.847: %LINK-3-UPDOWN: Interface GigabitEthernet0/4, changed state to up Oct 22 19:56:09.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan301, changed state to up Oct 22 19:56:09.847: %IFDAMP-5-UPDOWN: interface GigabitEthernet0/4 update IP Routing state to UP, interface is not suppressed Oct 22 19:56:09.847: %IFDAMP-5-UPDOWN: interface Vlan301 update IP Routing state to UP, interface is not suppressed Oct 22 19:56:11.415: %LDP-5-SP: 172.30.33.10:0: session recovery succeeded Oct 22 19:56:26.179: %OSPF-5-ADJCHG: Process 1, Nbr 172.30.33.10 on Vlan301 from LOADING to FULL, Loading Done Oct 22 19:56:26.179: %BFD-6-BFD_SESS_CREATED: BFD-SYSLOG: bfd_session_created, neigh 172.28.34.165 proc:OSPF, idb:Vlan301 handle:1 act
10-23-2020 10:06 AM
Can you post the show run the interface going down, and explain what i other device connected ?
Looks for me more of Pysical issue. Layer 1 /2 ?
10-23-2020 10:39 AM
CSG-65-01#sh run interface gi0/4 Building configuration... Current configuration : 320 bytes ! interface GigabitEthernet0/4 description link_FO_to_ME-34-01 dampening no ip address load-interval 30 carrier-delay msec 0 media-type sfp no negotiation auto cdp enable synchronous mode service instance 301 ethernet encapsulation untagged service-policy input setqosgrp bridge-domain 301 ! end
12-17-2024 04:29 AM
what is the solution for this?
