06-04-2012 06:44 AM
Hello
I am looking for all possible SW versions for a TCC3 card. Do you have to upgrade the IOS or just the module?
06-04-2012 09:44 AM
ffyyocum,
You can put either MSPP or MSTP software on the TCC3 card depending on your application. The latest is 9.4.0.1 is out for MSTP and 9.2.1.3 is out for MSPP. I believe after 9.2 for the MSTP you need to download the lite versions if you have a TCC3. It will state this on the software download page. You can find the download software page at the link below. You'll need a valid Cisco username/password and software license to download which will be stated on the download page.
http://www.cisco.com/cisco/software/navigator.html?mdfid=268437886&flowid=304
Hope this can get you started in the right direction.
Ryan
06-04-2012 09:53 AM
Thank you
