Transceiver issues with SFP-10G-SR-S and C9500-48Y4C
Stefan Bischoff
Hello together,
are there any knowm issues on compatibility for the original Cisco SFP-10G-SR-S and the C9500 Series switches?
We have the problem, that the inserted SFP+ are recognized as 1000BaseZX SFP and are in a non-functional state.
Working C9500 in the US running IOS 16.9.3, the interfaces show in inventory:
NAME: "TwentyFiveGigE1/0/24", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR-S        , VID: V01  , SN: AVD2147DCD3
NAME: "TwentyFiveGigE2/0/24", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR-S        , VID: V01  , SN: AVD2147DCDC
Not working ones, even after upgrading the switches to the most current version, Cisco recommended IOS (IOS XE Software, Version 16.12.04)
It appears these may be the wrong gbic, as they are displayed as SFP-10G-SR instead of SFP-10G-SR-S.
NAME: "TwentyFiveGigE1/0/48", DESCR: "GE ZX"
PID: SFP-10G-SR          , VID: V03  , SN: AVD2231D3TE
NAME: "TwentyFiveGigE2/0/48", DESCR: "GE ZX"
PID: SFP-10G-SR          , VID: V03  , SN: AVD2231D3RW
It seems that the modules are manufactured by the same company for Cisco, all of them are AVDxxxxxxxxx.
These are original Cisco SFP+, no third party modules!
Shall we return these SFP+ ?
Kind regards
Stefan
Leo Laohoo
That sounds like a bug.
Have you raised this issue with TAC?
14 Replies 14
Leo Laohoo
Hi Leo,
At the moment no, but we will do this, if there is no workaround available. In the bug tool there is no such issue present, so it seems something new.
Kind regards
Stefan
Stefan Bischoff
We have installed a workaround by using thirdparty modules now, but we have installed the failing modules as well, so a TAC case can be opened on them.
Kind regards
Stefan
Ruben Cocheno
@Stefan Bischoff
If you replaced the SFP, changed the fiber patch, upgraded the firmware, the last call is TAC RMA on the way
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Leo Laohoo
Please post the complete output to the following command:
show idprom interface <PORT> detail
Stefan Bischoff
Hello Leo,
that's the output of the command:
IDPROM for transceiver TwentyFiveGigE1/0/27:
  Description                               = SFP or SFP+ optics (type 3)
  Transceiver Type:                         = GE ZX (23)
  Product Identifier (PID)                  = SFP-10G-SR
  Vendor Revision                           = A0
  Serial Number (SN)                        = AVD2231D3TE
  Vendor Name                               = OEM
  Vendor OUI (IEEE company ID)              = 00.00.00 (0)
  CLEI code                                 = COUIA8NCAA
  Cisco part number                         = 10-2415-03
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 19/12/13
  Connector type                            = LC.
  Encoding                                  = 8B10B (1)
  Nominal bitrate                           = OC12/STM4 (600 Mbits/s)
  Minimum bit rate as % of nominal bit rate = not specified
  Maximum bit rate as % of nominal bit rate = not specified
  The transceiver type is 23
  Link reach for 9u fiber (km)              = IR-2(40km) (40)
                                              LR-1(40km) (40)
                                              DX(40KM) (40)
                                              HX(40km) (40)
  Link reach for 9u fiber (m)               = IR-2(40km) (255)
                                              LR-1(40km) (255)
                                              LR-2(80km) (255)
                                              LR-3(80km) (255)
                                              DX(40KM) (255)
                                              HX(40km) (255)
                                              ZX(80km) (255)
                                              VX(100km) (255)
  Link reach for 50u fiber (m)              = SR(2km) (0)
                                              IR-1(15km) (0)
                                              IR-2(40km) (0)
                                              LR-1(40km) (0)
                                              LR-2(80km) (0)
                                              LR-3(80km) (0)
                                              DX(40KM) (0)
                                              HX(40km) (0)
                                              ZX(80km) (0)
                                              VX(100km) (0)
                                              1xFC, 2xFC-SM(10km) (0)
                                              ESCON-SM(20km) (0)
  Link reach for 62.5u fiber (m)            = SR(2km) (0)
                                              IR-1(15km) (0)
                                              IR-2(40km) (0)
                                              LR-1(40km) (0)
                                              LR-2(80km) (0)
                                              LR-3(80km) (0)
                                              DX(40KM) (0)
                                              HX(40km) (0)
                                              ZX(80km) (0)
                                              VX(100km) (0)
                                              ESCON-SM(20km) (0)
  Nominal laser wavelength                  = 1310 nm.
  DWDM wavelength fraction                  = 1310.0  nm.
  Supported options                         = Tx disable
                                              Tx fault signal
                                              Loss of signal (standard implementation)
  Supported enhanced options                = Alarms for monitored parameters
                                              Software Tx disable
                                              Software Tx fault monitoring
                                              Software Rx LOS monitoring
  Diagnostic monitoring                     = Digital diagnostics supported
                                              Diagnostics are internally calibrated
                                              Rx power measured is "Average power"
  Transceiver temperature operating range   = not specified
  Minimum operating temperature             = 0 C
  Maximum operating temperature             = 70 C
  High temperature alarm threshold          = +75.000 C
  High temperature warning threshold        = +70.000 C
  Low temperature warning threshold         = +0.000 C
  Low temperature alarm threshold           =  -5.000 C
  High voltage alarm threshold              = 3630.0 mVolts
  High voltage warning threshold            = 3465.0 mVolts
  Low voltage warning threshold             = 3135.0 mVolts
  Low voltage alarm threshold               = 2970.0 mVolts
  High laser bias current alarm threshold   = 11.800 mAmps
  High laser bias current warning threshold = 10.800 mAmps
  Low laser bias current warning threshold  = 5.000 mAmps
  Low laser bias current alarm threshold    = 4.000 mAmps
  High transmit power alarm threshold       =  1.7 dBm
  High transmit power warning threshold     = -1.3 dBm
  Low transmit power warning threshold      = -7.3 dBm
  Low transmit power alarm threshold        = -11.3 dBm
  High receive power alarm threshold        =  2.0 dBm
  High receive power warning threshold      = -1.0 dBm
  Low receive power warning threshold       = -9.9 dBm
  Low receive power alarm threshold         = -13.9 dBm
  External Calibration: bias current slope  = 1.000
  External Calibration: bias current offset = 0
  SFP IDPROM Page 0xA0:
        000:        03 04 07 00 00 00 02 12 00 01
        010:        00 01 06 00 28 FF 00 00 00 00
        020:        4F 45 4D 20 20 20 20 20 20 20
        030:        20 20 20 20 20 20 00 00 00 00
        040:        53 46 50 2D 31 30 47 2D 53 52
        050:        2D 53 20 20 20 20 41 30 20 20
        060:        05 1E 00 36 00 1A 00 00 41 56
        070:        44 32 32 33 31 44 33 54 45 20
        080:        20 20 20 20 31 39 31 32 31 33
        090:        20 20 68 F0 01 37 00 00 06 C6
        100:        89 54 31 1E 4C D4 F6 D5 28 AF
        110:        A7 D5 A3 21 A2 00 00 00 00 00
        120:        00 00 00 00 6C 4F FF 5C 49 50
        130:        55 49 41 4C 4B 52 41 41 31 30
        140:        2D 32 31 34 34 2D 30 31 56 30
        150:        31 20 01 00 46 00 00 00 00 E8
        160:        00 00 00 00 00 00 00 00 00 00
        170:        00 00 00 00 00 00 00 00 00 00
        180:        00 00 00 00 00 00 00 00 00 00
        190:        AA AA 47 4C 43 2D 45 58 2D 53
        200:        4D 44 20 20 20 20 20 20 20 20
        210:        20 20 31 36 00 00 00 00 00 00
        220:        00 00 00 58
  SFP IDPROM Page 0xA2:
        000:        4B 00 FB 00 46 00 00 00 8D CC
        010:        74 04 87 5A 7A 76 17 0C 07 D0
        020:        15 18 09 C4 39 C7 02 E5 1C F5
        030:        07 46 3D E9 01 97 1F 07 03 FF
        040:        00 00 00 00 00 00 00 00 00 00
        050:        00 00 00 00 00 00 00 00 00 00
        060:        00 00 00 00 00 00 00 00 3F 80
        070:        00 00 00 00 00 00 01 00 00 00
        080:        01 00 00 00 01 00 00 00 01 00
        090:        00 00 00 00 00 10 9D 15 5D 82
        100:        5D 00 66 01 00 00 00 00 00 00
        110:        B2 00 05 40 00 00 05 40 00 00
        120:        FF FF FF FF FF FF FF 01 43 4F
        130:        55 49 41 38 4E 43 41 41 31 30
        140:        2D 32 34 31 35 2D 30 33 56 30
        150:        33 20 01 00 46 00 00 00 00 C6
        190:        AA AA 53 46 50 2D 31 30 47 2D
        200:        53 52 20 20 20 20 20 20 20 20
        210:        20 20 32 33 00 00 00 00 00 00
        220:        00 00 00 35 15 1A 20 24 2A 30
        230:        20 30 00 00 00 00 00 00 00 00
        240:        00 00 00 00 00 1D 00 00 FF FF
        250:        FF FF 00 00 00 00
Interesting is the wavelength of 1310nm, which is not a SR typical value of 850nm
Stefan
Stefan Bischoff
Leo,
thats an output of working ones at the USA from the same manufacturer:
IDPROM for transceiver TwentyFiveGigabitEthernet1/0/21:
  Transceiver Type:                         = SFP+ 10GBASE-SR (273)
  Product Identifier (PID)                  = SFP-10G-SR-S
  Vendor Revision                           = G4.1
  Serial Number (SN)                        = AVD2304DEPX
  Vendor Name                               = CISCO-AVAGO
  Vendor OUI (IEEE company ID)              = 00.17.6A (5994)
  CLEI code                                 = CMUIAK6CAA
  Cisco part number                         = 10-3105-01
  Date code (yy/mm/dd)                      = 19/02/20
  Encoding                                  = 64B/66B (6)
  Nominal bitrate                           =  (10300 Mbits/s)
  The transceiver type is 273
  Link reach for 9u fiber (km)              = SX(550/270m) (0)
                                              1xFC-MM(500/300m) (0)
                                              2xFC-MM(300/150m) (0)
                                              ESCON-MM(2km) (0)
  Link reach for 9u fiber (m)               = SX(550/270m) (0)
                                              ESCON-MM(2km) (0)
  Nominal laser wavelength                  = 850 nm.
  DWDM wavelength fraction                  = 850.0  nm.
                                              Tx fault signal
                                              Software Tx disable
  High laser bias current alarm threshold   = 10.500 mAmps
  High laser bias current warning threshold = 10.500 mAmps
  Low laser bias current warning threshold  = 2.500 mAmps
  Low laser bias current alarm threshold    = 2.500 mAmps
  External Calibration: bias current slope  = 0.000
        000:        03 04 07 10 00 00 00 00 00 00
        010:        00 06 67 00 00 00 08 02 28 1E
        020:        43 49 53 43 4F 2D 41 56 41 47
        030:        4F 20 20 20 20 20 00 00 17 6A
        040:        53 46 42 52 2D 37 30 39 53 4D
        050:        5A 2D 43 53 32 20 47 34 2E 31
        060:        03 52 00 40 00 1A 00 00 41 56
        070:        44 32 33 30 34 44 45 50 58 20
        080:        20 20 20 20 31 39 30 32 32 30
        090:        20 20 68 F0 03 58 00 00 06 A1
        100:        FD D3 0E 68 14 DE 26 DE FA FB
        110:        32 83 29 E3 7A 00 00 00 00 00
        120:        00 00 00 00 35 87 C4 53 00 00
        130:        00 00 00 00 00 00 00 00 00 00
        140:        00 00 00 00 00 00 00 00 00 00
        150:        00 00 00 00 00 00 00 00 00 00
        190:        00 00 00 00 00 00 00 00 00 00
        200:        00 00 00 00 00 00 00 00 00 00
        210:        00 00 00 00 00 00 00 00 00 00
        220:        00 00 00 00
        010:        74 04 87 5A 7A 76 14 82 04 E2
        020:        14 82 04 E2 39 C7 02 E5 1C F5
        060:        00 00 00 00 00 00 00 00 00 00
        070:        00 00 00 00 00 00 00 00 00 00
        080:        00 00 00 00 00 00 00 00 00 00
        090:        00 00 00 00 00 51 0E 19 78 82
        100:        0A 0C D2 16 E2 14 00 00 00 00
        110:        B2 00 00 40 00 00 00 40 00 00
        120:        00 00 1D 00 00 00 00 00 43 4D
        130:        55 49 41 4B 36 43 41 41 31 30
        140:        2D 33 31 30 35 2D 30 31 56 30
        150:        31 20 01 00 46 00 00 00 00 B8
        200:        53 52 2D 53 20 20 20 20 20 20
        210:        20 20 30 32 00 00 00 00 00 00
        220:        00 00 00 72 1E 20 2A 2A 31 34
        230:        29 36 00 00 00 00 00 00 00 00
        240:        00 00 00 00 00 56 00 00 FF FF
Kind regards
Stefan
Mccluskie70
I was looking for the same info, tried doing the same but it didn't worked. Thanks for spreading the knowledge walgreenslistens
kapydan88
Level 4
Level 4
Hello.
It works fine with 16.12.02 version
So-9500-core#sh inv | i SFP-10G-SR-S
So-9500-core#sh ver | i 16.12
Cisco IOS XE Software, Version 16.12.02
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.02, RELEASE SOFTWARE (fc2)
So-9500-core#
About possible causes of malfunction:
1) it is necessary to check grounding (9500 switches are very sensitive to it);
2) you can try disabling and enabling problem port.
3)is this sfp 10G original or not?
Stefan Bischoff
Thanks everyone for discussing this topic. The SFP+ are wrong branded, original Cisco SFP+. All defective SFP+ are replaced now and the new original ones are working - by the way they are now from Finisar, instead of Cisco Avago. I don't know why Cisco choosed Avago for manufacturing them.
Thanks a lot.
Kind regards
Stefan
Do you have sfp pictures and idprom output I have same problems
 thank you
Sorry,
I only posted the output of the idprom. I didn't took pictures from them.
 As you can read, they were wrong branded and identified as "GE-ZX"
Cisco replaced them and everything is fine now
Have a nice day
Kind regards
Stefan
But my transceiver still can't use
 Vendor name is cisco-avago
Transceiver type is SFP+ 10Gbase-SR
Which model I need to change for C9500 24y4c?
Hi Folks,
It is a normal issue.
Just interchange the LC connecting the SFP+. It works just fine.
Check: show idprom interface Interface name
           Show interfaces Interface name transceiver detail
Please note that the SFP+ module should be detected by the device.
The version of the C9500 switch we are running is:
CoreSwitch_01#show ver
Cisco IOS XE Software, Version 16.09.05
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.5, RELEASE SOFTWARE (fc1)
