09-16-2021 04:14 AM
BRIEF
DETAIL
N9K# sh int eth1/13 transceiver details
Ethernet1/13
transceiver is present
type is 1000base-LH
name is CISCO
part number is TRPUG1CLXECISE2G
revision is 01
serial number is OPM23170SHM
nominal bitrate is 1300 MBit/sec
Link length supported for 9/125um fiber is 10 km
cisco id is 3
cisco extended id number is 4
cisco part number is 10-2625-01
cisco product id is GLC-LH-SMD
cisco version id is V01
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 38.06 C 89.00 C -9.00 C 85.00 C -5.00 C
Voltage 3.29 V 3.59 V 3.00 V 3.50 V 3.09 V
Current 21.63 mA 69.90 mA 4.50 mA 64.95 mA 5.50 mA
Tx Power -6.25 dBm 0.99 dBm -13.56 dBm -3.00 dBm -9.50 dBm
Rx Power -9.24 dBm 0.99 dBm -23.01 dBm -3.00 dBm -19.20 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
N9K#
N9K# sh int eth1/13 status
Port Name Status Vlan Duplex Speed Type
Eth1/13 To CTL notconnec 2001 auto auto 1000base-LH
N9K#
HISTORY
--sk
Stuart Kendrick
09-16-2021 04:22 AM
Couple of testing :
1. try adding command - speed nonegotiate
config t
interfface eth x/x
speed nonegotiate
shut and no sut bot the sides
2. Try to twitst Fible lead
A----A
B----B
to
A---B
B---A
09-17-2021 03:47 AM
I would agree with speed nonegoiate being a feature needed some times. Have seen this ALOT with ASR9k 1000nv Satellite pannel -> ASR920 with 1G LX SFPs! Have to add/ remove the command on the correct side to get it to work, some times it is opposite of what we did last time
