WS-5486-LX verses WS-5486-LX/LH
prince.henry
We have a Cisco 7600 router with multiple GBIC modules.
Can you please confirm if there is a difference in a GBIC module marked as WS-G5486 1000BASE-LX and another marked as WS-G5486 1000BASE-LX/LH.
We have found that on one of our circuits, the LX cuases packet loss, but the LX/LH works fine.
The part numbers are the same and all the Cisco documentation we have suggests both modules are identical.
Can you please confirm.
viyuan700
Level 5
Level 5
"The Cisco 1000BASE-LX/LH GBIC (WS-G5486) fully complies with the IEEE 802.3z 1000BASE-LX standard. However, its higher optical quality allows it to reach 6.2 miles (10 kilometers) over single-mode fiber (SMF), compared with the 3.1 miles (5 km) specified in the standard."
This is the explanation from Cisco documentation. See the link
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet09186a008014cb5e_ps872_Products_Data_Sheet.html
This is the link for standard where it has given that length specified by standard is 5Km for 1000BASE-LX (you have to accept the terms and condition to see the standard)
http://standards.ieee.org/getieee802/download/802.3-2008_section3.pdf
Do you have info that what is the distance between the 2 1000BASE-LX cards?
Is 1000BASE-LX/LH also have the same distance?
randomcamden
If you find the answer, I'd love to know. Sounds exactly like the issue I have ;o)
Hi Neil Camden,
Do you have info like what type of card and distance between the cards?
If you tried some steps already to troubleshoot the problem.
I don't know what's the other end, or how far away it is... it's a carrier CE somewhere. I'm guessing from the symptoms that it's more than 550m away, which is why the LX GBIC doesn't work, but the LX/LH does.
