05-24-2004 10:57 PM - edited 03-13-2019 05:01 AM
In the datasheet, Cisco mentions :
NM-HD-2V
2-slot IP communications voice/fax network module.
Supports up to eight channels of analog/BRI voice using medium complexity codec or six channels using any supported codec. (No support for T1/E1 or data WAN)
However, when I start up this router, I only have 4 voice-ports, so 4 channels , BUT I have two VIC2-2BRI-NT/TE, so I would like to assign 8 channels ...
Does anyone have information/tips on this ?
Many Thanks
Dirk
05-25-2004 02:24 AM
Hi Dirk,
Check table 7.1
Also
The VIC-2BRI-NT/TE card should be installed in slot 0 of the NM-2V voice carrier card. The second VIC slot of the NM-2V must not have any other voice interface cards installed while an ISDN voice card is installed. This is necessary to ensure the NM-2V voice carrier card allocates the four Digital Signal Processor (DSP) resources correctly to the four available B channels on the two BRI ports. Only one BRI port would be active and ISDN voice calls may not work if the card is installed in slot 1 of the NM-2V card.
From
Dave
05-25-2004 04:33 AM
Hello Dave,
I checked your information, many thanks for that. But the module I have is an NM-HD-2V, not an NM-2V, so your information is right, but we are talking about another module.
Dirk
05-25-2004 04:45 AM
Hi Dirk,
You had me worried for a minute.
How about: -
The NM-HD-1V and NM-HD-2V have feature parity with the NM-1V and NM-2V, except there is currently no support for the following on NM-1V and NM-2V:
Trunked ATM Adaptation Layer 2 (AAL2) on analog ports
Universal Foreign Exchange Office (FXO) and CAMA
Dropping of DSPs on a Plain Old Telephone Service (POTS)-to-POTS call that stays within the network module.
Dave
06-14-2004 02:39 AM
Hi Dave,
the NM-HD-2V has feature parity, but the HD-2V DSPs allow twice as many channels as the non HD version, hence supporting 8 channels.
Cheers,
F
06-14-2004 12:42 AM
Hello Dirk,
Last week I installed the same combination and had the same problem. Couldn't pinpoint the problem to the router or the Dutch KPN. They are looking into this problem at the moment.
Do you have the same sort of ISDN2 line with a static TEI=0 ?
Regards, Sjaak
06-14-2004 02:29 AM
The NM-HD-2V supports your configuration. According to the Table 5 of
http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html
"Requires at least one Cisco VIC (maximum of two): VIC2-2BRI-NT/TE"
on the show ver, how many isdn ports show up?
Cheers,
F
06-14-2004 04:30 AM
Agreed. Sorry don't have captured the sh vers, but with sh ISDN status I can see only 2 with layer 1 Active the other is De-activated. When using the De-activated port this one is activated and another is De-activated. Also I see a message about Clk and Guido change. It really seems only 2 ISDN ports can be active at the same time.
Regards, Sjaak
06-14-2004 06:38 AM
Hi.
The best way to see what is goinbg wrong is to do a show diag and see if the nm and vics come up.
Below is the relevant part of a show diag of a WIC-2BRI-NT/TE on a NM-2V on the slot 2 of a 3640. (yours hopefully will be different :))) )
Slot 2:
4 PORT Voice PM for MARs Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision H0
Serial number 21563213 Part number 800-02491-02
FRU Part Number: NM-2V=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 65 01 01 01 49 07 4D 50 09 BB 02 00 00 00 00
0x10: 88 00 00 00 00 07 25 17 FF FF FF FF FF FF FF FF
VIC Slot 0:
NT or TE BRI Voice daughter card (2 port)
Hardware revision 1.0 Board revision D0
Serial number 28015004 Part number 800-07272-03
Connector type PCI
0x20: 01 32 01 00 01 AB 79 9C 50 1C 68 03 00 00 00 00
0x30: 68 00 00 00 02 05 06 00 FF FF FF FF FF FF FF FF
07-06-2004 06:11 AM
Pinpointed the problem to the physical connection between the NT1 and CO. It took the provider some time to locate this problem.
