12-28-2004 08:20 AM - edited 03-15-2019 03:11 AM
I can't seem to get MGCP to register. The Debug MGCP events says the error is 'Socket drained'.
Here's a Show Run. I'm running 4.0(2a)sr1 CCM and the router is running 12.3.11T2
CMHHQ384501#sh run
Building configuration...
Current configuration : 1853 bytes
version 12.3
hostname CMHHQ384501
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.12.100.10
ccm-manager mgcp
ccm-manager config server 10.12.100.10 12.12.100.11
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
framing esf
linecode b8zs
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.12.100.251 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0:23
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.12.100.1
ip http server
ip http authentication local
ip http secure-server
control-plane
voice-port 0/0/0:23
mgcp
mgcp call-agent 10.12.100.11 service-type mgcp version 1.0
mgcp dtmf-relay voip codec all mode out-of-band
mgcp package-capability rtp-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp profile default
dial-peer voice 100 pots
application mgcpapp
port 0/0/0:23
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
CMHHQ384501#
12-28-2004 08:31 AM
Your configuration should be pushed from the CM, as you have ccm-manager config commands configured. So what does a "show ccm-manager" look like ?
The only command that I see missing on this config is under the serial interface
int s0/0/0:23
isdn bind-l3 ccm-manager
This should automatically be pushed by the server, but try adding this command and see if that helps! Also is your ISDN status (Layer 1 active, Layer 2 - MULTIPLE_FRAME_ESTD) -- Do a "show isdn status" to find out!!
Hope that helps!
Sankar.
12-28-2004 08:38 AM
Here's a show isdn status. I do have the isdn bind-L3 ccm-manager command in there but it goes away after a reboot.
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 2
Total Allocated ISDN CCBs = 0
12-28-2004 08:51 AM
Pls issue the following commands and post the results
no mgcp
wait for 5 secs
mgcp
sh mgcp endpoints
Arijit
12-28-2004 09:00 AM
Have you checked with your telco to see if they can see your equipment. (Try putting a hard loop at the Smart jack and see if they can see the loop. Also try connecting the hard loop to the t1 controller and see if the LP light is lit and the controller status changes to state UP)..Have you verified switch types with the Telco ?
Please paste output of "debug isdn q921" in your next post!
What does "show ccm-manager" indicate ?
Also try a "no mgcp" and "mgcp" on the router manually to reset MGCP and see if that helps!
