7914 module with 7961 phone and CCME 3.2
kritskiy_monstr
I have an 2811 router running CCME 3.2.
I want to setup 7914 expansion module with IP Phone 7961. The phone loads normally, but expansion module doesn't load at all. All buttons are red.
What should I put in ephone description on CCME to make 7914 module work?
Can such combination (7961 + 7914) work with CCME 3.2?
Thanks in advance!
goldbergj
in the ephone config try this:
type 7960 addon 1 7914
Please rate helpful posts :)
JG
With such configuration of ephone 7961 does not load at all. And there is no possibility to enter "addon" keyvord after type 7961 in CCME 3.2. I think that upgrading CCME is the only way.
Rob Huffman
Hi Alexander,
7961G phones are supported on CME starting with 4.0 have a look at this good doc;
Cisco Unified CallManager Express 4.0 Supported Firmware, Platforms, Memory, and Voice Products
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00805f5908.html
Here is the feature history;
12.4(9)T
12.4(4)XC
New IP phone support
Cisco Unified IP Phone 7911G
Cisco Unified IP Phone 7941G and Cisco Unified IP Phone 7941G-GE
Cisco Unified IP Phone 7961G and Cisco Unified IP Phone 7961G-GE
From this doc;
Cisco Unified CME 4.0 Features
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a80c8.html#wp2289750
Hope this helps!
Rob
Please remember to rate helpful posts......
