08-05-2009 06:36 AM - edited 03-13-2019 06:33 PM
Can I use 7941G/7961G firmware for new cisco phone 7942G/7962G?
08-05-2009 06:41 AM
Hi Irfan,
No, these are different firmwares. They may look similar but note the difference in these examples;
For the 7942/7962
SCCP42.8-3-4SR1S
For the 7941/7961
SCCP41.8-3-4SR1S
Hope this helps!
Rob
08-05-2009 06:48 AM
Thanks, But even after that if I use the older version of firmware SCCP41.8-3-4SR1S the new phone 7942/7962 not going to be functional?
08-05-2009 09:26 AM
You need to use the SPECIFIC FW for phone models, few phones like 7940/60 share the same file.
Go to downloads at cisco and you'll get the current versions PER DEVICE MODEL
Simply download the ones for the right models you have
java
if this helps, please rate
