7970 load 6.01 loses customization after reboot
stephan.steiner
Since I've upgraded my CM (4.01) to SR2, my 7970 is behaving a bit weird. Every 2nd time I reboot the phone, it loses the background image and ringtone customization. Another reboot and things are back to normal. Immediately after the upgrade, the phone first booted using the old load, then when I reset it, it keep on looping, resetting itself a few seconds after coming online, until after 5/6 iterations it stayed up, but without the proper ringtone/background selection. And since then my customization is not loaded for every 2nd reboot (note that it doesn't get lost.. another reboot and everything is back to how it should be).
Has anybody else experienced this?
Not applicable
There are some known issues regarding this. Check if you are hitting the bug "CSCec42845".
