addTransPattern in CCM 4.2
consorzio
Dear All.
I'm getting crazy with "addTransPattern" method.
In CCM 4.1 if i send an AXL request like this:
<m:addTransPattern xmlns:m="http://www.cisco.com/AXL/API/1.0" >
<newPattern>
<pattern>00999999955555555.[23456789]XXX</pattern>
<description>TEST Translation</description>
<usage>Translation</usage>
<routePartitionName></routePartitionName>
<blockEnable>false</blockEnable>
<calledPartyTransformationMask></calledPartyTransformationMask>
<callingPartyTransformationMask></callingPartyTransformationMask>
<useCallingPartyPhoneMask>Off</useCallingPartyPhoneMask>
<callingPartyPrefixDigits></callingPartyPrefixDigits>
<dialPlan uuid="{714EAFF8-55C2-11D3-B52D-0008C7C6A4C6}">
<name>NANP</name>
<description>North American Numbering Plan</description>
</dialPlan>
<dialPlanWizardGenId>0</dialPlanWizardGenId>
<digitDiscardInstructionName></digitDiscardInstructionName>
<messageWaiting>Lamp Off</messageWaiting>
<networkLocation>OnNet</networkLocation>
<patternUrgency>true</patternUrgency>
<prefixDigitsOut></prefixDigitsOut>
<routeFilterName></routeFilterName>
<callingLinePresentationBit>Default</callingLinePresentationBit>
<callingNamePresentationBit>Default</callingNamePresentationBit>
<connectedLinePresentationBit>Default</connectedLinePresentationBit>
<connectedNamePresentationBit>Default</connectedNamePresentationBit>
<supportOverlapSending>false</supportOverlapSending>
<patternPrecedence>Default</patternPrecedence>
<releaseCause>No Error</releaseCause>
<allowDeviceOverride>false</allowDeviceOverride>
<provideOutsideDialtone>true</provideOutsideDialtone>
<callingSearchSpaceName></callingSearchSpaceName>
</newPattern>
</m:addTransPattern>
i create translation with success.
BUT
if i send the same request to CCM 4.2 i get this error:
<SOAP-ENV:Fault>
<faultcode>SOAP-ENV:Client</faultcode>
<faultstring>
<![CDATA[Unexpected element. <callingSearchSpaceName> is not a valid element of this request type or the sequence of tags is wrong.]]></faultstring>
<detail xmlns:axl="http://www.cisco.com/AXL/API/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.cisco.com/AXL/API/1.0 http://DGGMPSCCMTEST/CCMApi/AXL/V1/axlsoap.xsd">
<axl:error sequence="0">
<code>5005</code>
<message>
<![CDATA[Unexpected element. <callingSearchSpaceName> is not a valid element of this request type or the sequence of tags is wrong.]]></message>
<request>addTransPattern</request>
</axl:error>
</detail>
</SOAP-ENV:Fault>
It seems that <callingSearchSpaceName> is not good element. If i remove this tag from my request it says that <callingSearchSpaceName> is needed...
Any hint? Am i wrong? Or this is the latest example of AXL bug in a new CCM version?
Noone is working with CCM 4.2?
Thank you
consorzio
Excuse me.. i was in error because as i can read in "Cisco CallManager 4.2(1) AXL Programming Guide" the "addTransPattern" method was changed.
Now the question is how and where i can find the new definitions for this (and the other) methods....
Anyone knows the right link?
nathan.a.reeves
I managed to get the addTransPattern to work. The only difference with my request and the one you documented above was that I didn't have the value set. Everything else was included in my query and the CSS name was blank.
A dump of the vars I was inserting:
Array ( [newpattern] => Array ( [pattern] => 123XXXX [description] => Test Pattern [usage] => Translation [blockEnable] => false [calledPartyTransformationMask] => 5XXX [callingPartyTransformationMask] => [useCallingPartyPhoneMask] => Off [callingPartyPrefixDigits] => 00 [dialPlan] => Array ( [name] => AUNP [description] => Australia Numbering Plan 1.1(4) [uuid] => {976DBDAF-2D76-41BB-B0DD-75994744AF97} ) [dialPlanWizardGenId] => 0 [digitDiscardInstructionName] => [messageWaiting] => Lamp Off [networkLocation] => OnNet [patternUrgency] => true [prefixDigitsOut] => [routeFilterName] => [callingLinePresentationBit] => Default [callingNamePresentationBit] => Default [connectedLinePresentationBit] => Default [connectedNamePresentationBit] => Default [supportOverlapSending] => false [patternPrecedence] => Default [releaseCause] => No Error [allowDeviceOverride] => false [provideOutsideDialtone] => true [callingSearchSpaceName] => ) )
Dear Mr Nathan
Thank you for your message.
Did you test the "addTransPattern" method in CCM 4.2? Does it works?
Thank you.
Sorry for the delay. Yes, the addTransPattern was tested in 4.2(1) and it worked fine.
cheers
Nathan
