caller id on fxo with router running MGCP
shaun.white
All,
I have a voice gateway with a Caller ID enabled FXO card...the gateway is running MGCP...however im not seeing caller id being passed to the phone...what do i need to do?
TIA
gogasca
Level 10
Level 10
Change to H323.
No support for callerID with FXO running MGCP
I have the same issue and have converted to H.323. Now caller ID only works while SRST is enabled. When the gateway (1760) is communicationg with my CCM cluster (pub+sub) caller ID does not work. I have tried playing w/ the dial peers listed below and changing them to a more H.323 like version but have had no luck.
Here are my fist 6 dial peers that connected and incoming call on the FXO port to the CCM cluster prior to H.323 mode:
dial-peer voice 1 pots
service mgcpapp
port 2/0
dial-peer voice 2 pots
service mgcpapp
port 2/1
dial-peer voice 3 pots
service mgcpapp
direct-inward-dial
port 3/0
dial-peer voice 4 pots
service mgcpapp
direct-inward-dial
port 3/1
dial-peer voice 5 pots
service mgcpapp
direct-inward-dial
port 3/2
dial-peer voice 6 pots
service mgcpapp
direct-inward-dial
port 3/3
Once I change them to something like below I can no longer dial in, I get a busy signal.
dial-peer voice 1 voip
preference 1
ip precedence 5
destination-pattern .T
voice-class h323 1
session target ipv4:192.168.2.12
dtmf-relay h245-alpha
dial-peer voice 2 voip
preference 2
ip precedence 5
voice-class h323 1
session target ipv4:192.168.2.10
Any ideas?
tia - Mike
Well, you still need POTS dial-peers when using H.323.
Add the following:
description 911 calling
direct-inward-dial
incoming dialed-number .
destination-pattern 911
forward-digits all
port 2/0
description local calling
destination-pattern [2-9]......
forward-digits all
port 2/0
description ld calling
destination-pattern 1[2-9]..[2-9]......
forward-digits all
port 2/0
description international calling
destination-pattern 011T
forward-digits all
port 2/0
repeat the above for all FXO ports, add "preference" command that will increament for every port, for example port 2/1 dial-peers will have "preference 1", port 3/0 preference 2, etc.
HTH,
Chris
