04-30-2009 03:57 AM - last edited on 03-25-2019 06:58 PM by ciscomoderator
I have tried to register a couple of analogic phones on a UC500, they are plugged on the FXS ports but they always get busy line.
I have used the mac that appeared on the Configuration Assistant but I don't really know if the FXS mac for each port is the right one.
I have the following configuration and I can't find any error, I hope someone can help me out:
voice-port 0/0/0
cptone ES
timeouts ringing infinity
description EXT_6002
voice-port 0/0/1
cptone ES
description EXT_1002
voice-port 0/0/2
cptone ES
description EXT_6001
voice-port 0/0/3
cptone ES
description EXT_3333
ephone-dn 5 dual-line
number 3333 no-reg primary
label 3333
description Disenadores Disenadores
name Disenadores Disenadores
call-forward noan 1999 timeout 17
huntstop channel
ephone-dn 6 dual-line
number 6002 no-reg primary
label 6002
description Desarrolladores B
name Desarrolladores B
huntstop channel
ephone-dn 33 dual-line
number 1002 no-reg primary
label 1002
description Inaki Aliaga
name Inaki Aliaga
huntstop channel
ephone-dn 34 dual-line
number 6001 no-reg primary
label 6001
description Desarrolladores A
name Desarrolladores A
huntstop channel
ephone 24
device-security-mode none
mac-address B8FA.EBB0.0000
max-calls-per-button 2
username "Disenadores" password 12345
type anl
button 1:5
ephone 25
mac-address B8FA.EBB0.0001
username "DesarrolladoresB" password 12345
type anl
button 1:6
ephone 26
mac-address B8FA.EBB0.0002
username "InakiAliaga" password 12345
type anl
button 1:33
ephone 27
mac-address B8FA.EBB0.0003
username "DesarrolladoresA" password 12345
type anl
button 1:34
04-30-2009 05:28 AM
Hi friend, did you try to configure the FXS port as:
voice-port 0/0/0
cptone ES
dial-peer voice TAG pots
destination-pattern 6002
port 0/0/0
Without using ephone configuration for analog phones.
Best regards
David
04-30-2009 07:00 AM
Unfortunately I have already tried that when i use your option on the phone where i am trying to call from it appears ring out and no sound comes up.
When i use the other option with ephone and ephones-dn at least i get the busy signal.
I have no idea how to fix the matter.
Really appreciated your help, thanks
04-30-2009 07:47 AM
Hi again, can you call to an ip phone from the analog phone?
Try configuring this command in your fastethernte interface:
"h323-gateway voip bind srcaddr ip address"
and
voice rtp send-recv
Best regards
David
05-03-2009 10:41 PM
Seems it works now!!My sophone seems to get block whenever i try to call this analog phones but not with ip phones. Anyway from another phone works perfectly all communication, probably my sophone went crazy but no explanation for it. Thank you the important stuff is fixed.
