10-07-2008 08:59 AM - edited 03-15-2019 05:04 AM
I HAVE A 24 PORT AVG. OUT OF WHICH I AM CONNECTING A TOTAL OF 10 ANALOGUE SUBSCRIBERS LOCALLY. I NEED TO GIVE CONNECTIVITY TO 10 SUBSCRIBERS LOCATED AT APPROX 5 KMS. OFC CONNECTIVITY IS AVAILABLE BETWEEN BOTH THE LOCATIONS. GIVE ME SUGGESTION ABOUT THE END EQUIPMENT CONNECTIVITY TO CONNECT 10 ANALOGUE TELEPHONES AT REMOTE END USING THE EXISTING OFC MEDIA.
10-13-2008 07:07 AM
The Cisco VG 224 is a Cisco IOS Software-based high-density 24-port gateway for analog phones, fax machines, modems, and speakerphones within an enterprise voice system based on Cisco Unified CallManager.
10-17-2008 03:35 AM
Where are you planning to install VG224?
Easy way installs VG224 at subscriber lactation. Use the RAS opti-mux for Ether connectivity.
