Power supply issue
vaibhav-g
Hi Team
We are facing an issue in which both power supply goes down after 30-45 minutes and again it came back with this message.
unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
plse confirm this is issue with power supply or any software issue is their
Vaibhav
testeven
Hi!
I guess this happening on a Catalyst 6500. If that's the case you might want to check this TAC case collection:
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K32364218
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Great work
Thanks a lot
Hi Tere
actually here my both power supplies goes down after 30-45 minutes and after restarting the same it again work for the same period and we found the above message ,kindly let me know is this related to this power supply or IOS issue is their
