AS5300 - Voice Port Configuration Problem
stephan_maurer
Hi guys,
I'm trying to configure a E1 PRI 8 Port Module on a AS5300 (IOS: 12.3(18)) but after I configured the controller, I can't find the voice ports. if I do a sh voice port summ there are no voice ports listed.
The controller is showing up in sh controllers e1 0.
Also under the dial-peer there is no port command..
Anybody has had this issue before?
Thanks.
Best regards
5 Replies 5
Harmit Singh
Hi Stephan,
As requested in the other post, please provide the show version and show run output. Also, show diag output for this post.
Harmit.
Hi Harmit,
thanks for the reply.
here are the show commands. i've added sh isdn status and sh controll e1 0.
Thanks.
Best regards
here are the outputs:
Router#sh vers
IOS (tm) 5300 Software (C5300-JS-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 15-Mar-06 16:39 by dchih
Image text-base: 0x60008AEC, data-base: 0x618EC000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.1(17), RELEASE SOFTWARE (fc1)
Router uptime is 3 hours, 53 minutes
System returned to ROM by reload at 16:26:08 gmt Sun Jan 2 2000
System image file is "flash:c5300-js-mz.123-18.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory.
Processor board ID 14898234
R4700 CPU at 150MHz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 1.80, Item Number 800-2544-03,
Board Revision A0, Serial Number 14898234,
PLD/ISP Version 0.0,  Manufacture Date 8-Jul-1999.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
35 Serial network interface(s)
240 terminal line(s)
8 Channelized E1/PRI port(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Router#sh run
Building configuration...
Current configuration : 2057 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable password cisco
spe 1/0 2/9
firmware location system:/ucode/mica_port_firmware
resource-pool disable
clock timezone gmt 2
no aaa new-model
ip subnet-zero
ip cef
isdn switch-type primary-net5
isdn voice-call-failure 0
voice call send-alert
voice rtp send-recv
voice service pots
voice service voip
sip
voice class codec 1
voice class codec 100
controller E1 0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1
clock source line secondary 1
controller E1 2
clock source line secondary 2
controller E1 3
clock source line secondary 3
controller E1 4
clock source line secondary 4
controller E1 5
clock source line secondary 5
controller E1 6
clock source line secondary 6
controller E1 7
clock source line secondary 7
interface Ethernet0
no ip address
interface Serial0
no ip address
clock rate 2015232
no fair-queue
interface Serial1
no ip address
clock rate 2015232
no fair-queue
interface Serial2
no ip address
clock rate 2015232
no fair-queue
interface Serial3
no ip address
shutdown
clock rate 2015232
no fair-queue
interface Serial0:15
no ip address
encapsulation hdlc
isdn incoming-voice modem
no cdp enable
interface FastEthernet0
ip address 1.1.1.1 255.255.255.252
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 1.1.1.2
no ip http server
dial-peer voice 100 voip
destination-pattern .T
session protocol sipv2
session target ipv4:192.168.1.1
session transport udp
dtmf-relay rtp-nte
dial-peer voice 10 pots
direct-inward-dial
sip-ua
no remote-party-id
sip-server ipv4:192.168.1.1
line con 0
line 1 240
line aux 0
line vty 0 4
transport input lat pad mop telnet rlogin udptn
end
Router#
Router#sh diag
Motherboard Info:
EEPROM format version 0
EEPROM contents (hex):
   0x00: 00 01 01 30 01 50 03 20 00 09 F0 03 41 00 31 34
   0x10: 38 39 38 32 33 34 00 00 00 00 00 00 00 00 13 63
   0x20: 07 08 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
   0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FRU NUMBER : AS5300
Slot 0:
Hardware is Octal E1 PRI, 8 ports
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x49,
Board Hardware Version 1.0, Item Number 800-3883-01,
Board Revision A0, Serial Number 14896274,
PLD/ISP Version 0.1,  Manufacture Date 29-Jun-1999.
   0x00: 00 01 01 49 01 00 03 20 00 0F 2B 01 41 00 31 34
   0x10: 38 39 36 32 37 34 00 00 00 00 00 00 00 00 13 63
   0x20: 06 1D 00 01 FF FF FF FF FF FF FF FF FF FF FF FF
FRU NUMBER : AS53-8CE1+=
Slot 1:
Hardware is Duo Density Modems
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x4C,
Board Hardware Version 1.0, Item Number 800-3680-01,
Board Revision A0, Serial Number 14049055,
PLD/ISP Version 2.2,  Manufacture Date 7-Jul-1999.
   0x00: 00 01 01 4C 01 00 03 20 00 0E 60 01 41 00 31 34
   0x10: 30 34 39 30 35 35 00 00 00 00 00 00 00 00 13 63
   0x20: 07 07 02 02 FF FF FF FF FF FF FF FF FF FF FF FF
FRU NUMBER : AS53-120-CC2=
Slot 2:
Board Revision A0, Serial Number 14055218,
   0x10: 30 35 35 32 31 38 00 00 00 00 00 00 00 00 13 63
Router#
here are the other two.
Router#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
Router#
Router#
Router#sh controll
Router#sh controllers e1 0
E1 0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info of slot 0:  HW: 1, PLD Rev: 11
  Framer Version: 0x8
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (593 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
  Data in Interval 2:
     4 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     4 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 3:
  Data in Interval 4:
     5 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     5 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 5:
  Data in Interval 6:
     3 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 7:
  Data in Interval 8:
  Data in Interval 9:
  Data in Interval 10:
  Data in Interval 11:
  Data in Interval 12:
  Data in Interval 13:
  Data in Interval 14:
  Data in Interval 15:
  Data in Interval 16:
  Data in Interval 17:
  Data in Interval 18:
  Data in Interval 19:
     5 Line Code Violations, 0 Path Code Violations
     3 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins
  Total Data (last 19 15 minute intervals):
     5 Line Code Violations, 0 Path Code Violations,
     61 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins,
     63 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Router#
Hi Harmit,
we upgraded to 12.3(26) but still same issue. no voice ports are showing up.
Router#sh voice port summ
                                     IN       OUT
PORT      CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
Router#
Thanks.
Best regards
