ata-186 (3.1) with Bogen paging system (help!!)
trailman73
Level 4
Level 4
I have the ata-186 configured in ccm 4.0.1 and it works great with an analog handset. Now when I plug it into the Bogen TPU-100A it gives a dial-tone over the speakers, then a "call can't be completed as dialed" message then a fast busy and disconnect. What am I missing here?
I really appreciate your help,
Geoff
campbelb
You may need to simulate an audio paging port using an e&m interface. Check out the url below for the details.
http://www.cisco.com/en/US/partner/tech/tk652/tk653/technologies_configuration_example09186a008015094e.shtml
Thanks for the link, do you have it without the "partner" login?
I thought that I could use the ata and it would just place a call to the external paging speakers?
You will need to look at the Bogen TAM-B. This will allow a FXS connection to the TPU100.
