ATA 186 port 2 issue
jadecerega
I have a CCM running 3.3(3) and all ATA's 186 are register and can make and received calls from the PSTN through a Gateway with PRI ( E1's ). The problem appears when I trie to make a call to the private network from port # 2 .
thisisshanky
Level 11
Level 11
Have you checked whether line number 2 on each ATA has registered with the CCM ? Do you have partitions and calling search spaces ? If yes check to see if the Calling Search space of the gateway have the ATA line 2's partition listed and vice versa.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
