ATA remote location design recommendation
vladimir
I have the following setup. Essentially I am trying to give remote users the ability to use a phone from home. Users' IP address is a dynamic public IP and the Linksys router provides NAT (PAT). Also, I NAT on the PIX.
What is the recommended setup? Do I "talk" SCCP to call manager? Do I use a gatekeeper?
-- PIX -- Cisco IOS -- Internet -- Linksys RTR -- ATA
-------7960
--------DT24+ (PRI)
------Call Manager
Thank you,
Vladimir
j-block
Level 4
Level 4
Yes, I think the ATA should talk SCCP to call manager. You may deploy Gatekeeper if you want to do any call admission control, else you will not need it.
