AutoAttendant Problem
liangxing-lin
I setup AutoAttendant which shiped with CCM 3.3,
I found a problem, I can't sure it's my wrong setup or it's a system BUG. Anyone meet this problem ?
How resolved?
What's aa.aef ?
Problem Description:
From PSTN make a call to company, AutoAttendant auto answered, prompt caller to press 1 for extension, press 2 for search by name. After caller press 1, he can place ANY phone call. For example, After caller press 1, then he can place a phone call to USA,UK....any phone number. (It should be limited within company inside extension)
How resolved it ? H.322 GW configuration as below;
dial-peer voice 1 pots
destination-pattern 9T
direct-inward-dial
port 1/1:15
dial-peer voice 4620 voip
destination-pattern 801
session target ipv4:10.1.1.3
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 2 pots
destination-pattern T
direct-inward-dial
port 1/1:15
num-exp 32203333 801
pbarman
Level 5
Level 5
The 4 CTI Ports that are configured for the AA, to which Calling Search Space does they belong. If they belong to a CSS that has partition(s) to which the long distance, international route patterns are assigned, then you will observe this behaviour.
Assign the CTI ports to a more restrcitive CSS that has only the partition to which the company internal extensions are assigned. If the company extensions do not belong to any partition, then donot assign the CTI ports to any CSS.
aa.aef is the auto-attendant script that in invoked whenever you call the AA route point number.
Hope this helps!
