AXL: subscribeCallingSearchSpace for users
schemberg
we use extension mobility for all users, so we have to use the SubscribeCSS inside the end-user settings. (the subscribeCSS for the phone only works without EM-Login).
We had a look at the documentation but, this is not part of AXL to set subscribeCSS for users (add-/updateUser).
Any help welcome.
With kind regards
Axel
dhook
Level 5
Level 5
It seems this field have'nt made it into the API yet. The information about which css a user has is stored in the enduser table in the field "fkcallingsearchspace_restrict" as a guid. You could use executeSQLUpdate to put the information in there.
Kind regards,
//Dan-Anders
dhook
Level 5
Level 5
Kind regards,
//Dan-Anders
Hi Dan,
thank you for your reply, I will have a look at.
Axel
