07-25-2005 05:41 AM - edited 03-13-2019 09:54 AM
I need to change the "location" field for a large number of handsets. All the users are extension mobility users and remain logged in. This field cannot be changed whilst someone is logged into the phone.
Is there someway I can bulk logout all users ? If I set the "Enforce Maximum login time" to a low value (currently not used) would that achieve the affect ? or would that only apply from the next time the user logs in ?
07-29-2005 08:28 AM
You can make use of the "EM AUTO LOGOUT" to logoff the users.
08-02-2005 06:07 AM
Changing the max login time will only affect users who log in after that change has been done on CM. There is no way of doing a bulk logout of EM users. However a tool has been developed (not Cisco) that can do a bulk logout for you. If you require more details get in touch as its not a published app.
08-02-2005 08:14 AM
Hi Daniel
I had the same problem a couple of months ago and had to do it the hard way. Is the tool free?
colin
08-02-2005 01:15 PM
Unfortunately its not free, a friend of mine developed it, I don't think he charges very much, email him at fertmeola@yahoo.co.uk if you're interested.
08-03-2005 01:32 PM
I have created a tool too, (flexible in all bulks stuff)
a plugin can be created to do your bulk logout,
all you would need is a list of devicenames
it is not free, but not expensive...
