02-03-2016 04:34 AM - edited 03-13-2019 09:19 PM
Cisco has announced that "C887VA-V-K9" has been end of sale.
what is the replacement for it for which match Small branches requirement for 2x FXO and 5x SRST
BR
Mamdouh
Solved! Go to Solution.
02-04-2016 04:52 AM
02-03-2016 07:17 AM
You can use C881-V-K9
Srini
02-03-2016 09:01 PM
Yes Srini
but I was looking for a small ISR with 1/2 FXO ports instead off the BRI
BR
Mamdouh
02-04-2016 04:52 AM
The 881 does come in a 1 port fxo configuration
Srini
02-04-2016 05:12 AM
thanks a lot
02-04-2016 05:08 AM
See here
C881-V-K9
Cisco881, FE WAN, 4 FXS, 2BRI, 1FXO
SRST
C881SRST-K9
Cisco 881 SRST Ethernet Security Router with FXS, FXO
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Table 22
Srini
02-05-2016 01:43 AM
Thank you for your information
