Cisco has announced that "C887VA-V-K9" has been end of sale.
what is the replacement for it for which match Small branches requirement for 2x FXO and 5x SRST
BR
Mamdouh
Solved! Go to Solution.
You can use C881-V-K9
Srini
Yes Srini
but I was looking for a small ISR with 1/2 FXO ports instead off the BRI
BR
Mamdouh
thanks a lot
See here
C881-V-K9
Cisco881, FE WAN, 4 FXS, 2BRI, 1FXO
SRST
C881SRST-K9
Cisco 881 SRST Ethernet Security Router with FXS, FXO
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Table 22
Srini
Thank you for your information
