Call Manager and HP switches?
rgaudet
I have a scenario of having an infrastructure of HP Procurve switches. I have 802.3af PoE to the access layer. The switches support QoS, VLAN, LLDP (not CDP), etc... I am interested in Cisco Call Manager to replace current Avaya based PBX's. Can this be done? Better yet, do you think Cisco will support it?
pklos
Level 4
Level 4
Should work, only disadvantage is that you'll have to manually configure each phone with Voice VLAN ID (Administrative VLAN ID).
regards,
pk
it is not true anymore you need to set the vlan ID.
blackmichael
Cisco phone support LLDP which will act the same as CDP. I have done this on 796x and 7975 phones and it works great. You just need to make sure you are on the lastest firmware that supports it.
http://h40060.www4.hp.com/procurve/uk/en/pdfs/application-notes/AN-C3_ProCurve-Cisco-IP-phone-7900-final-101308.pdf
