caller ID display problem
yeopaul
Voice and Video
Forum Topics > Conversations > Outline > Messages
I can't get this caller ID display to work. at present, all outgoing calls display only the main pri number instead of individual number. The Telco has confirmed that the line can support individual caller ID display.
I have tried to configure the external phone number mask for each line like 68275XXX where XXX is my 3 digit extension. but it doesn't work out.
what are the steps to get this thing done? Can any other CCM/voice gateway setting offset what I have done?
append is my voice gate config:
logging buffered 4096 debugging
aaa new-model
aaa authentication password-prompt PASSWORD(Authorized-User-Only):
aaa authentication username-prompt USERNAME(Authorized-User-Only):
aaa authentication login default local
clock timezone SGP 8
ip subnet-zero
no ip source-route
ip audit notify log
ip audit po max-events 100
isdn switch-type primary-net5
no call rsvp-sync
no voice hunt unassigned-number
no voice hunt invalid-number
voice service voip
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
voicecard mode gateway
controller E1 1/0
pri-group timeslots 1-31
description : : First E1 line to PSTN
controller E1 1/1
description : : Second E1 Line to PSTN
translation-rule 68275
Rule 0 ^682756.% 6
Rule 1 ^682757.% 7
Rule 2 ^682758.% 8
interface Loopback0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0.5
interface GigabitEthernet0/0
no ip address
no negotiation auto
interface GigabitEthernet0/0.1
description : : Virtual Routing Interface for Voice VLAN
encapsulation dot1Q 50
ip address 10.178.196.252 255.255.255.0
ip helper-address 10.178.223.11
interface GigabitEthernet0/0.2
description : : Virtual Routing Interface for User VLAN
encapsulation dot1Q 4
ip address 10.178.192.252 255.255.255.0
interface GigabitEthernet0/0.4
encapsulation dot1Q 1 native
interface GigabitEthernet0/0.5
description : : Virtual Routing Interface for ETPL VLAN
encapsulation dot1Q 3
ip address 10.178.204.252 255.255.255.0
ip helper-address 10.178.204.4
interface GigabitEthernet0/0.10
description : : Virtual Routing Interface for Server VLAN
encapsulation dot1Q 2
ip address 10.178.223.250 255.255.255.0
interface Serial1/0:15
description : : First E1 line D-Channel to PSTN
no ip address
no logging event link-status
isdn incoming-voice voice
isdn T309-enable
isdn send-alerting
isdn sending-complete
no cdp enable
interface Serial1/1:15
description : : Second E1 line D-Channel to PSTN
no ip address
isdn T309-enable
isdn send-alerting
no cdp enable
ip default-gateway 10.178.223.1
ip http server
ip http access-class 80
ip classless
ip route 0.0.0.0 0.0.0.0 10.178.223.1
ip route 10.178.203.0 255.255.255.0 10.178.223.251
ip pim bidir-enable
logging trap debugging
voice-port 1/0:15
input gain 1
output attenuation 1
echo-cancel coverage 24
cptone SG
voice-port 1/1:15
input gain 1
cptone SG
dial-peer voice 10 voip
incoming called-number 68275...
destination-pattern 68275...
progress_ind setup enable 3
translate-outgoing called 68275
session target ipv4:10.178.196.1
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip precedence 5
no vad
dial-peer voice 100 pots
preference 1
destination-pattern ........
progress_ind alert enable 8
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 101 pots
preference 1
destination-pattern 9........
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 102 pots
preference 1
destination-pattern 1800T
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 103 pots
preference 1
destination-pattern 6.......
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 104 pots
preference 1
destination-pattern 1...
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 105 pots
preference 1
destination-pattern 800T
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 106 pots
preference 1
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 200 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 201 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 202 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 203 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 204 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 205 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 206 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
voicecard sccp manager 10.178.196.1 port 2000
voicecard sccp local Loopback0
voicecard conference
voicecard transcode
end
6 Replies 6
robrhodes
Level 3
Level 3
Verify that you have the presentation bit set to allowed in your gateway config on CCM. Debug q931 on your voice gateway to show what calling number you are passing to the carrier.
I have set the presentation bit to on. when I do a debug Q931, I can see the calling party number is the full number passing to the carrier. e.g. 68275606.
i am using CCM 3.1a.
do you think reinstalling the call manager will work?
I had experienced a problem where the carrier was not passing on caller id but was passing all calls and masking them with the main DID number.
Might be an idea to check if they're restricting any caller id information.
If you see, in CCM traces or debugs from the GW, that the digits are send outbound, talk with your provider and make sure you have the exact digit format they expect to get from you. If you miss that format all calls are "Private" or no-CLID.. for example: your extension is 8001, your main,/lead number is 02-1234-8001 but your provider expects you to send 2-1234-8001 (note that the 0 has been ommited) they will add the extra 0!.
Again, you need to have a tlak with them to find out the exact digit format they expect to get from you.
Danny M.
bcowley
In CallManager, under the gateway, make sure you have the appropriate numbering plans setup. If you leave them as CallManager, The Telco may reject the IE. So in North America you would set the Calling Party IE Number Type Unknown to National and The Calling Numbering Plan to ISDN
Hi folks,
Thanks so much. I tried to change the calling party IE number type to National and the Calling numbering plan to ISDN, it works.
Thank you very much,
Paul
