Can VoIP & VoFR work together?
admin_2
Level 3
Level 3
I have a network where part of that network is working with VoFR, now the costumer wants to implement VoIP in another part of the network; question is:Can the users that are working with the VoFR schema talk with users that are going to use VoIP schema?
Is there any way we can have working together both schemas VoIP and VoFR?
Not applicable
Vofr call leg to voip call leg is not supported.
You need to voip end-to-end or vofr end-to-end. I would
suggest a slow migration to voip. Extra QOS would be required on links already used
for vofr since voip traffic would be seen as data
traffic over thie F/R links unless the right QOS is put in place.
Old post I know but does the new ip2ip command fix this?
No. If you need to transition from vofr/votam/voip you need to connect back-to-back pots interface in the router and have dsp, an isdn bri card would do 4 channel, an E1/t1 23 or 30.
