11-24-2004 03:02 AM - edited 03-13-2019 07:08 AM
Hi, I have CCM 4.0.2a and purchased four Tandberg Videoterminal 1000. Haw to add this SCCP device to be visible in CCM. I found on cisco cco that I should in "Add a Phone Device" choose SCCE Video Endpoint or Tandberg Video Endpoint but in my CCM this is not available (I can't choose this). What I missed during installing CCM ? What can be done to solve this problem ?
Thanks for any suggestions !
Maciej Flak
Solved! Go to Solution.
11-24-2004 06:33 AM
Hello, I'm happy about your good news.
Please mark the post as a solved one, so that it might be of help to others.
Thanks and regards
11-24-2004 03:25 AM
Hello, If you have purchased the tandberg licensed to use with SCCP, you should have a plugin to install it at the Call Manager (contact with your Tandberg distributor).
With this plugin you'll see the Tandberg Video Endpoint at the "Add a Phone Device" menu.
11-24-2004 03:29 AM
11-24-2004 06:25 AM
Well, This is what I was looking for !!! Great Thanks !!
Maciej
11-24-2004 06:33 AM
Thanks and regards
