09-08-2004 06:12 AM - edited 03-15-2019 03:01 AM
I am looking to confirm if CCM 4.x now supports MGCP fractional PRI when using MGCP PRI backhaul.
We know it doesn't in 3.x see bug id CSCed41207, but I would like to know if this support has now been added in CCM's newer versions?.
Many Thanks
Paul
Solved! Go to Solution.
09-08-2004 09:21 AM
Paul,
This has still not been added yet.
There is still the workaround for using up to 5 MGCP gateways using the ServiceParameters, but it's just as well staying with H.323 for fractional deployments at present.
Roy.
09-08-2004 09:21 AM
Paul,
Roy.
09-09-2004 01:14 AM
Roy,
Thnaks for the reply.
Please could you confirm what the workaround is. I wasn't aware / can't remember!. It would be nice to know what service parametrs are configured so I can try it in our lab.
If our customers are going to use fractional E1's we tell them to use H.323.
Brgds
Paul
09-09-2004 04:54 AM
There is an advanced CallManager service parameter: Change B-Channel Maintenance Status X, where X is 1-5. So far up to 5 controllers you are able to busy out channels per cluster.
