CCM4.x & MGCP fractional PRI
paulclilverd
I am looking to confirm if CCM 4.x now supports MGCP fractional PRI when using MGCP PRI backhaul.
We know it doesn't in 3.x see bug id CSCed41207, but I would like to know if this support has now been added in CCM's newer versions?.
Many Thanks
Paul
rdonalds
Paul,
This has still not been added yet.
There is still the workaround for using up to 5 MGCP gateways using the ServiceParameters, but it's just as well staying with H.323 for fractional deployments at present.
Roy.
rdonalds
Paul,
Roy.
Roy,
Thnaks for the reply.
Please could you confirm what the workaround is. I wasn't aware / can't remember!. It would be nice to know what service parametrs are configured so I can try it in our lab.
If our customers are going to use fractional E1's we tell them to use H.323.
Brgds
Paul
There is an advanced CallManager service parameter: Change B-Channel Maintenance Status X, where X is 1-5. So far up to 5 controllers you are able to busy out channels per cluster.
