09-16-2004 03:04 AM - edited 03-13-2019 06:22 AM
hi,
i setup a simple net with ccme. all works fine but on incoming the caller number is not displayed on phone (it display private).
the gateway is the same router where ccme is running, the external line are connected to a BRI interface on NM-2V module
i check with debug isdn q931 and the "calling party number" is right
thanks
stefano
09-16-2004 08:03 AM
Can you paste the CME configs ? and also debug isdn q931 output ?
09-20-2004 04:35 AM
here the relevant config
ip cef
ip dhcp excluded-address 172.31.1.220 172.31.1.255
ip dhcp excluded-address 172.31.1.1 172.31.1.119
ip dhcp pool IPTel
network 172.31.1.0 255.255.255.0
option 150 ip 172.31.1.2
default-router 172.31.1.1
dns-server 151.99.125.2 151.99.125.3 62.94.0.1
interface FastEthernet0/0
ip address 172.31.1.2 255.255.255.0
duplex auto
speed auto
interface BRI1/0
no ip address
isdn switch-type basic-net3
isdn incoming-voice voice
isdn answer1 xxxxxx
interface BRI1/1
no ip address
isdn answer1 xxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 172.31.1.1
ip http server
ip http authentication local
ip http path flash:
tftp-server flash:P00403020214.bin
tftp-server flash:P00303020214.bin
voice-port 1/0/0
compand-type a-law
connection plar 100
description ISDN access for Texor
bearer-cap Speech
voice-port 1/0/1
compand-type a-law
no comfort-noise
cptone IT
connection plar 200
bearer-cap Speech
dial-peer voice 100 voip
dial-peer voice 1000 pots
preference 1
destination-pattern 0T
clid strip
port 1/0/0
dial-peer voice 1001 pots
preference 2
clid strip
port 1/0/1
telephony-service
load 7910 P00403020214
load 7960-7940 P00303020214
max-ephones 20
max-dn 25
ip source-address 172.31.1.2 port 2000
auto assign 1 to 15
timeouts interdigit 2
user-locale IT
create cnf-files version-stamp 7960 Jul 26 2004 14:42:04
max-conferences 4
moh music-on-hold.au
time-format 24
date-format dd-mm-yy
web admin system name xxxx password xxxx
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 0
ephone-dn 1 dual-line
number 101
pickup-group T
label Stefano@101
name Stefano
call-forward busy 501
call-forward noan 501 timeout 25
ephone-dn 2 dual-line
number 102
pickup-group T
label F@102
ephone-dn 3 dual-line
number 103
label A@103
ephone-dn 20 dual-line
number 100
pickup-group T
label T@100
ephone-dn 25 dual-line
number 501
pickup-group T
label Reception@501
ephone 1
mac-address 0030.94C3.1594
type 7960
button 1:1 3:20
ephone 20
mac-address 0030.94C3.1575
type 7960
auto-line incoming
button 1:25 3:20 4:21
and this is the q931 debug
7w2d: %LINK-3-UPDOWN: Interface BRI1/0, changed state to up
7w2d: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 73 changed to up
7w2d: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x51
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x0181, '335xxxxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, 'yyyyyyy'
Plan:ISDN, Type:National
High Layer Compat i = 0x9181
7w2d: ISDN BR1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xD1
Channel ID i = 0x89
7w2d: ISDN BR1/0 Q931: TX -> ALERTING pd = 8 callref = 0xD1
Progress Ind i = 0x8188 - In-band info or appropriate now available
7w2d: ISDN BR1/0 Q931: RX <- RELEASE pd = 8 callref = 0x51
Cause i = 0x8090 - Normal call clearing
7w2d: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xD1
the 335xxxxxx is forwarded to the phone.
thnx
stefano
09-20-2004 05:48 AM
Please take out the commands "clid strip" from the dial-peers 1000 and 1001.
Anup
09-20-2004 06:42 AM
Solved. thnx.
stefano
