06-07-2005 08:31 AM - edited 03-13-2019 09:23 AM
My Max Calls/Busy Trigger default to 4/2 I want the default to be 2/1. Is there a way to change the defaults on this setting? I would also like to change the default on the external number mask.
06-13-2005 12:13 PM
You can use the procedure mentioned the following document
06-13-2005 12:33 PM
Unfortuantly, I have beenr eading that document and can not find the answer in it. Is the default Max Busy/Trigger preset in the phone load? If so how would I change it?
I just hate to change it everytime I add a phone.
