Cisco 2821 to Inter-tel PBX Configuration Problems
smartin
Trying to connect a 2821 to a PBX system (T1) card.
Cisco 2821
1. VWIC-2MFT-T1 card for 2 connections to the PBX
2. 2 - WIC-1DSU-T1-V2 for connection to the ISP
3. PVDM2-16 - DSP Module
4. PVDm2-32 - DSP Module
I believe I have a configuration problem with the DSP's & the "voice-card". Getting the following error when in debug mode.
PilotVoice(config)#no dspfarm
PilotVoice(config)#dspfarm
No dsp resources available or allocated; check dsp availability
and allocate voice card(s) for dspfarm
Listed below is my configuration & my "sh diag" log.
Any help would be greatful.
5 Replies 5
dgahm
Level 8
Level 8
Dspfarm configuration is only required for transcoding or conference bridging. Your 48 DSP channels will be needed for your 2 voice T1s (assuming G711 codec, you will need more for G729).
If you require a DSP farm on this router you will have to add more DSPs.
Are you using a Call Manager, or is this a H323 VOIP transport setup? You config does not show any dial peers or MGCP stuff, but perhaps you just posted a partial?
Dave
This will be a VOIP Transport setup, I did'nt setup any dial peers yet because I'm trying to first establish a connection between the router & the PBX system.
On the inter-tel PBX system I'm trying to match the settings on their T-1 card. The settings are
Framing Type - Extended Superframe
Zero Code Suppression - B8ZS
Line Build-Out - Auto
Start Type - Wink
Both controllers are "up" but on the PBX T-1 card I'm getting "Red" blinking error alarm.
Can I remove "DSPFARM" under voice-card ??
This is what I have in a working 2821 with a CAS T1:
voice-card 0
no dspfarm
If you have a red alarm on your PBX you probably have a cabling problem. Is the router showing a yellow remote alarm?
On the VWIC card AL is lite. Using straight RJ45 to RJ45 cables (patch). Did a "sh controller T1" getting the controller is down. A ciso tech ensured me that I could use this type of cable, am I wrong ?
Thanks...
T1 0/2/0 is down.
Applique type is Channelized T1
Cablelength is long gain36 0db
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20040202, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 0.
Data in current interval (126 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 126 Unavail Secs
T1 0/2/1 is down.
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
Data in current interval (128 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 128 Unavail Secs
You need a T1 crossover. The 2 pairs used are pins 1,2, and 4,5. Your cable should be wired like this:
1 to 4
2 to 5
4 to 1
5 to 2
An Ethernet crossover will not work.
