Cisco ACS for VOIP accounting
pwheelehan
I have a Cisco ACS server for AAA. My gateway router is setup on it as a TACACS+ Cisco IOS Hosts. The router has aaa commands
aaa authentication login default group tacacs+ local
aaa authentication login LOCAL local none
aaa authentication enable default group tacacs+ enable
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network h323 start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting connection h323 start-stop group tacacs+
i get voip logging in the TACACS+ accounting reports. But these are very time consuming to parse out call logging info. Do i need to change my gateway router to a radius host and change the aaa authentication and accounting commands to have the voip log in the voip and radius accounting reports on the ACS server?
thanks
