Cisco Hyper-v vision
adnanhassan1
Hi Guys,
Does anyone knows if Cisco IPT moving to Hyper-v in near future? Becauase there's some rumors that Cisco thinking to move to Hyper-v plateform soon?
Adnan
Hi Adnan,
More and more Cisco platforms/applications are being tested and supported with Hyper-V , you can check for compatibility of each app/platform individually by looking at their install guides / release notes.
Manish
Manish Gogna
Hi Adnan,
If you are looking for some official word on Hyper-V roadmap that is not posted on any customer facing Cisco docs yet then please engage your local Cisco SE / Account Manager for the same.
Manish
- Do rate useful posts -
Hi Manish,
Thanks for your reply.
It's more for myself becuse I heard Cisco is considering to move on Hyper-v. just wondering if this is correct? If so, what will be time line?
Hi Adnan,
Manish
That kind of information on future plans, roadmap, etc. is considered NDA, you would need to reach out to your SE/AM as Manish has pointed out.
java
if this helps, please rate
