Cisco IP Phone 8832NR Phone Load
Rohit Khajuria
Hi All
Could someone please tell me how to remove/delete the Inactive Phone Load from the Phone ?
Jaime Valencia
You can't, for phones with dual bank this is similar to the active/inactive partitions for CUCM
java
if this helps, please rate
Jaime Valencia
java
Hi Jaime, Thanks for the reply.
So I have a query then. Whenever the phone gets rebooted it takes the inactive load and phones will remain in the unregistered state. Then when pressing * while reboot, it comes with the active load and gets registered.
So could you please guide me how to overcome this problem ?
Rohit
okay. so I have a query then.
Whenever the phone reboots, it takes the inactive load and phone will remain in Unregistered state. and when pressing * whil;e rebooting, the phone comes up with the active load and gets registered.
So how to deal with this ?
Rohit
