When i try to upgrade my CM 5.0 from 5.0.3.1000-1 to 5.0.4.1000-1 it fails with the following error:
<upgrade-result>
<result>error</result>
<description>Upgrade No Result</description>
</upgrade-result>
Some Error in result file from application install:
<?xml version="1.0" encoding="UTF-8"?>
<upgrade-result>
</upgrade-result>
I'm using the "cisco-ipt-k9-patch5.0.4.1000-1.tar.gz" update file
Anybody seen this before?
Dom
